Author Topic: rattle problem  (Read 1718 times)
Offline Khare
  • The bear that khares
Re: rattle problem
« Reply #10 on: 20 June 2009, 10:36 »
cheap aftermarket mounts from e-bay mate
I had issue with the cheaper ones would start rattling after a week or so, try genuine ones they are not that more expensive.
I first thought it was top mounts, so I changed them for febi GSF units, it sorted it for a few days but came back (I realised while coilovers were off, I sprayed WD40 on them, so it was that what fixed it.
Try the spraying first, you don't have to remove the coilover, just remove the rear wheels.
Offline gazpowells
Re: rattle problem
« Reply #11 on: 20 June 2009, 20:34 »
didn't get chance to have a look today but have just been out and sprayed WD40 all over the springs
will go for drive in morning and see what happens (cant drive now had a few beers  :smiley:)
if that fails will get some genuine mounts ordered
thanks for help guys  :smiley:
Offline DAVEMARX
Re: rattle problem
« Reply #12 on: 21 June 2009, 10:36 »
Check for any loose brake calipers....
I had a rattle for ages and found out the brake caliper had come loose from the hub  :laugh:
dave
