Golf mk3
hardmonkeys
vr6 timing
Topic: vr6 timing (Read 1163 times)
JONESY16V
vr6 timing
18 June 2009, 12:40 »
is there any one out there that can help me with timing marks on a vr6 ? like where they are and how to set it up ? as i think mines jumped a tooth because of loose chain !! help
VRDan
GTI forum regular
VR6ing all the way home
Re: vr6 timing
18 June 2009, 19:22 »
At the top of the Crank pulley there is a notch on outer edge i think, that lines up with another notch on the block/back cover. You will have to remove the inlet manifold to get the rocker cover off to check the cams, They have nothes cut in the end that are offset so a locking tool or something (i used side of spanners) can only be put in one way to lock them in place.
Hope this helps
My VRSex!!
VRDan
GTI forum regular
Re: vr6 timing
18 June 2009, 19:29 »
http://forums.vwvortex.com/zerothread?id=1264409
This is a very good guide i have used in the past
My VRSex!!
AudiA8Quattro
Forum addict
Re: vr6 timing
19 June 2009, 00:08 »
The slots in the end of the cams need to be dead horizontal.
see
http://vwpolo2000.proboards.com/index.cgi?board=howto1&action=display&thread=141
JONESY16V
Re: vr6 timing
19 June 2009, 10:28 »
cheers your a star
Golf mk3
hardmonkeys
vr6 timing
