Author Topic: 90 or 110 BHP?  (Read 1999 times)
Offline Adam
Re: 90 or 110 BHP?
« Reply #10 on: 17 June 2009, 14:00 »
Aww no fun in that.
I remember the old 306 1.9 td engine. So easy to tune! From 90bhp to 110 was easy on them, just a few adjustment.
Down Hill From Here.
Re: 90 or 110 BHP?
« Reply #11 on: 17 June 2009, 14:02 »
Aww no fun in that.
To be honest on most older diesel it was easy to up the fueling but could lead to them being smoky.
Offline Adam
Re: 90 or 110 BHP?
« Reply #12 on: 17 June 2009, 14:57 »
Aww no fun in that.
no smoke, no poke
Offline Mikester
  • Civic Type R
Re: 90 or 110 BHP?
« Reply #13 on: 17 June 2009, 15:00 »
Aww no fun in that.
no smoke, no poke, no headgasket failure
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: 90 or 110 BHP?
« Reply #14 on: 17 June 2009, 18:27 »
The TDI is direct mechanical injection but is electronically controlled.  (common rail like PD engines have electronic injectors)
Sadly the only way to get decent power is a remap,  however a remap does make an impressive diffrence!
You might be able to fiddle with the boost controller but i find if you bleed air off it will throw up a control diffrence fault and go into limp mode on the dual carriage way,  unplugging the boost valve will put it into a constant limp mode.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
