Golf mk2
drilled airbox pic?
Topic: drilled airbox pic? (Read 3363 times)
dubsport
TDI POWAR!
drilled airbox pic?
15 June 2009, 22:39 »
anyone have a pic of an 8v airbox they have drilled? just want to make sure i drill the holes in the right place
thanks
Khare
Serious forum addict
The bear that khares
Re: drilled airbox pic?
15 June 2009, 22:41 »
mk3 -
dubsport
TDI POWAR!
15 June 2009, 22:43 »
cheers buddy! so its the bottom part nearest the wing
Gloves88
15 June 2009, 22:45 »
Fairly went to town on that lol
Just make sure the holes are on the wing side and below the filter. Engine side will cause it to suck in warm air
ReDBull
15 June 2009, 23:01 »
I've just taken the hot air feed of the back of the air box and feed a cold air pipe to it. Not fitted it yet so don't know if there'll be any improvment.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread:
http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Mr Blue
Forum addict
15 June 2009, 23:33 »
the noise will make you wish you didnt drill it.
dubsport
TDI POWAR!
16 June 2009, 00:17 »
i thought you got an iduction noise doing it?
ReDBull
16 June 2009, 09:17 »
Quote from: dubsport on 16 June 2009, 00:17
You do that's why I'm going back to an air box instead of a induction kit. You can also remove the inlet and trumpet on the front of the box. This will give you move induction noise and if you get board of it you can replace it.
My project thread:
Golf mk2
drilled airbox pic?
