Author Topic: drilled airbox pic?  (Read 3362 times)
Offline dubsport
  • TDI POWAR!
drilled airbox pic?
« on: 15 June 2009, 22:39 »
anyone have a pic of an 8v airbox they have drilled? just want to make sure i drill the holes in the right place  :grin:
thanks
Offline Khare
  • The bear that khares
Re: drilled airbox pic?
« Reply #1 on: 15 June 2009, 22:41 »
mk3 -
Offline dubsport
  • TDI POWAR!
« Reply #2 on: 15 June 2009, 22:43 »
cheers buddy! so its the bottom part nearest the wing  :smiley:
Offline Gloves88
« Reply #3 on: 15 June 2009, 22:45 »
Fairly went to town on that lol
Just make sure the holes are on the wing side and below the filter. Engine side will cause it to suck in warm air
Offline ReDBull
« Reply #4 on: 15 June 2009, 23:01 »
I've just taken the hot air feed of the back of the air box and feed a cold air pipe to it. Not fitted it yet so don't know if there'll be any improvment.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Mr Blue
« Reply #5 on: 15 June 2009, 23:33 »
the noise will make you wish you didnt drill it.  :lipsrsealed:
Offline dubsport
  • TDI POWAR!
« Reply #6 on: 16 June 2009, 00:17 »
i thought you got an iduction noise doing it?  :undecided:
Offline ReDBull
« Reply #7 on: 16 June 2009, 09:17 »
You do that's why I'm going back to an air box instead of a induction kit. You can also remove the inlet and trumpet on the front of the box. This will give you move induction noise and if you get board of it you can replace it.
