Author Topic: Fitting a chip  (Read 2040 times)
Offline carlos85
Fitting a chip
« on: 15 June 2009, 10:39 »
I've got a ecu chip that i would like to fit, but when i've opened up my ecu there is two chips that can be replaced. One is on the main board and the other is on a small board. Which is the one i replace?
Offline carlos85
Re: Fitting a chip
« Reply #1 on: 15 June 2009, 20:28 »
anyone?
Offline Neo Badness
  • Feet are for pedals
Re: Fitting a chip
« Reply #2 on: 16 June 2009, 00:16 »
Try posting in remapping or asking R-Tech
http://www.golfgtiforum.co.uk/index.php?board=74.0 :wink:
Offline carlos85
Re: Fitting a chip
« Reply #3 on: 16 June 2009, 10:28 »
that's more to do with there company
Offline Dan34
  • VTEC Powerzzzz
Re: Fitting a chip
« Reply #4 on: 16 June 2009, 11:46 »
Not exactly, its a section for remapping/tuning they just moderate and sponsor it, they will be happy to help you im sure.  :smiley:
Dan
Offline maxp
  • J reg 8v digi gti
Re: Fitting a chip
« Reply #5 on: 16 June 2009, 12:21 »
Doesnt the ignition module sit on top of the ecu?
They have quite a large size difference tho.
Offline danny_p
Re: Fitting a chip
« Reply #6 on: 16 June 2009, 12:30 »
the chip goes on the main board.
some digifant2 2 ecu's have 1 chip some have 2 .   most places used to put a blanck chip in the 2nd socket.  may be abel to tak erht e chip out and just leave it empty possobly
all the VW's have gone bar 1.
Offline Neo Badness
Re: Fitting a chip
« Reply #7 on: 16 June 2009, 12:37 »
Dan
Thankyou... :rolleyes:
Offline carlos85
Re: Fitting a chip
« Reply #8 on: 16 June 2009, 13:28 »
so the chip on the smaller board isn't used? just need to sort the fuel pump out now as it's still running even with the engine off & no key  :huh:
Offline danny_p
Re: Fitting a chip
« Reply #9 on: 16 June 2009, 14:52 »
well i had a look at the chips on beavis digifast before he killed it.
it once was a two chip ECU,   the eprom on the main board had the same amount of data on it as the eproms from te singel eprom ecu's and the 2nd eprom on the daughter board was blank
