Author Topic: Fitting a chip  (Read 2042 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Fitting a chip
« Reply #10 on: 16 June 2009, 22:18 »
reason for that is to make it a 2 letter code ecu instead of one..
oh and ive not killed it, the chip seems to be OK still  :wink:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline danny_p
Re: Fitting a chip
« Reply #11 on: 16 June 2009, 22:50 »
i just wondering dose the 2nd chip have to be there, obviously if the 2nd chip is present and has data on it'll bugger everything up.  but  empty v's no chip dose it make a differane ?
all the VW's have gone bar 1.
Offline carlos85
Re: Fitting a chip
« Reply #12 on: 17 June 2009, 10:30 »
is the second chip not a back-up?
Offline danny_p
Re: Fitting a chip
« Reply #13 on: 17 June 2009, 12:36 »
don't think so
Offline cняis
Re: Fitting a chip
« Reply #14 on: 17 June 2009, 20:24 »
surely theres no point to removing the 2nd chip?
the chip you replace on when you buy these 'higherpeaks' +6hp chips is the one on the MAIN board, beneath an H shaped white plastic holder/cover. theres a specific orientation to the chip denoted by a notch.
Offline danny_p
Re: Fitting a chip
« Reply #15 on: 17 June 2009, 20:32 »
thats what we were trying to work out if the 2nd chip did anythign in std form,   looks liek it's allways blank then   ok thats optimal just leave it allone
Offline cняis
Re: Fitting a chip
« Reply #16 on: 17 June 2009, 20:35 »
now im trying to work out which chip i have fitted ('performance' or OE), as neither had any markings on them as far as i know.... the one in my hand is blank...  :huh:
i know i took the 'performance' one back out when it started pinking but not sure whether i stuck it back in...  :undecided:
Offline danny_p
Re: Fitting a chip
« Reply #17 on: 17 June 2009, 23:56 »
you can normaly tell by the numbers
the std chips are a 27c64 ( it'll be in the manuafacturers  part number on the chip ) but 27c256 chips are nigh on inpossible to locate now so the performance chip is quite likely to be a 27c128 or 27c256  ( most common as they are still redialy avalible )
if there both 27c64's  i chould read them for you and mark them
Offline cняis
Re: Fitting a chip
« Reply #18 on: 18 June 2009, 19:48 »
will whip the ECU out on the weekend and check the numbers, thanks. i now have a vac problem again too...  :sad:
