Author Topic: Skittish over bumps  (Read 2157 times)
Offline admc6
Skittish over bumps
« on: 14 June 2009, 21:52 »
Hi all,
My gti has always seemed a little skittish over bumps, especially at the back.
Doesn bother me too much, but means you cant have as much run  :laugh:
Any ideas what would cause this? or are all mk3 gti life this?
Offline shepgti
Re: Skittish over bumps
« Reply #1 on: 14 June 2009, 21:54 »
had this exact same feeling with my standard shocks, it went when i fitted my coilies so i would say change the suspension!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 14 June 2009, 21:58 »
is it running standard shocks and springs? Do you know if the rear axle bushes or top mounts have been changed in it's lifetime?
Offline AudiA8Quattro
« Reply #3 on: 14 June 2009, 22:00 »
Rear axle bushes are shot.
« Reply #4 on: 14 June 2009, 22:01 »
Does sound that way.
Offline shepgti
« Reply #5 on: 14 June 2009, 22:05 »
mine are fine but still had the issues
Offline admc6
« Reply #6 on: 14 June 2009, 22:08 »
Its running on standard shocks and springs.
Dont think they have been changed, but will have a look through history. Do they not check them in one way or another when its serviced?
« Reply #7 on: 14 June 2009, 22:10 »
i very much doubt it tbh, plus most garages are scared to go anywhere near them unless they think they can get some major wedge from your pocket.
Offline admc6
« Reply #8 on: 14 June 2009, 22:12 »
Is there anyway to check them?
Not that it matters too much as i'm going to get a suspension kit for it as sson as i can afford it
« Reply #9 on: 14 June 2009, 22:16 »
A suspension kit of any kind won't cure the problem IF it is the rear axle bushes though. Id start by visually inspecting them to see if the rubber core looks perished, split and loose from it's metal housing. Then maybe jack up the rear end of the motor and see if you can lever / find any play inbetween the axle and axle mount on the floor pan.
