Author Topic: Engine mounts to use when fitting 1.8t into mk3  (Read 1744 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 12 June 2009, 23:08 »
thought i could just use the brackets off my 1.4 but i took the rear engine mount off the 1400 and it doesnt line up to the holes on the 1.8t - not sure if the 2.0 8v/16v or vr rear mount would fit the 1.8t?
wondered if anyone could shed some light on it :undecided:
cheers :)
Offline Adam
Re: Engine mounts to use when fitting 1.8t into mk3
« Reply #1 on: 16 June 2009, 13:20 »
I'm sure the 8v/16v/and vr6 are all the same LL. The VR6 has a different front mount.
Down Hill From Here.
Offline danny_p
« Reply #2 on: 16 June 2009, 14:48 »
use mounting brackets from 1.8 or 2ltr 8 or 16v
all the VW's have gone bar 1.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 16 June 2009, 18:51 »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 17 June 2009, 18:48 »
Hang on... I thought they were all the same? I know the TDI/16v and VR6 mounts are bigger and stronger but the holes in the right place still...?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 18 June 2009, 08:46 »
this is what i thought, its not vw to make them different... but hey, on the 1.4 bracket, the holes are closer together... maybe they are the same as the polo, cause isnt the 1.4 polo engine the same block?
« Reply #6 on: 18 June 2009, 10:16 »
the actual mounts and holes on car are same in terms of fitment, but the 1.4, 1.6 and 2.8 blocks are a completly different shape to the 1.8-2.0 hence why engine brackets differ.
Offline jimmy_20v
« Reply #7 on: 18 June 2009, 15:03 »
One other thing to watch out for here is that the rear engine brackets differ for cars fitted with the 02a cable change box from those fitted with the 020 box.  The bracket for cars with the 02a is slightly longer than for those with the 020.  Many don't realise this however it can be vital when converting to a 1.8t to get enough clearance between the cambelt cover and the brake master cylinder.
