Author Topic: will 18's fit mk3  (Read 6096 times)
Offline DAVEMARX
will 18's fit mk3
« on: 12 June 2009, 19:16 »
at the moment ive got stock suspenstion on 17's but i want to drop it 40mm with 18's
will they fit or do i need the arches folded?
whats the widest wheel and tyre size i can fit and do i need spacers etc
cheers
dave
Offline DAVEMARX
Re: will 18's fit mk3
« Reply #1 on: 12 June 2009, 19:23 »
while im here my interia has seen better days and i really need to change it..
While at the scrappy at the weekend i found a mk4 with really nice seat.
Do they fit the mk3 and if not hhow much work is involved to make them fit?
I was thinking of a steering wheel swap aswell with airbag from the same mk4.
are they a simple swap with the same electrics for the airbag??
dave
Offline VR6-Joe
« Reply #2 on: 12 June 2009, 19:30 »
Why the fook would you wanna put 18's on a Mk3? 16's are more than enough, 17's can look good.. but 18's? Seriously :huh:
No, Mk4 seats will not fit, unless you weld the correct mounts onto the floorpan iirc
Not sure how much work is involved fitting a Mk4 steering wheel but I think it is quite a tricky job, try and track one down from a 3.5 cabby :wink:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 12 June 2009, 19:33 »
18's will make the car drive shi7e!! and looks bad too!
seats would need mk3 subframes welding to them
mk4 will not fit easily (you'd need to modify the wiring quite a bit) but as said the mk3.5 (mk4 cabrio) wheel is a direct fit
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 12 June 2009, 20:08 »
cheers
dave
Ewwww....  :sick:
Offline Len
« Reply #5 on: 12 June 2009, 20:12 »
On 18's you will need 35 profile or even 30 if you want to go as wide as poss (215)
So being sensible "wildest" you can go is 215 wide tyres on 17x8 wheels.
www.sas.org.uk
www.the-ace.org.uk
« Reply #6 on: 12 June 2009, 20:21 »
I struggled with 17"s why you want to go bigger is beyond me.
Offline ace
« Reply #7 on: 12 June 2009, 20:25 »
18's will be too big for a mk3, pretty sure u would prob need arch work done as well
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #8 on: 12 June 2009, 20:37 »
when fitting big rims on a mk3 its all about width not height.
« Reply #9 on: 12 June 2009, 20:40 »
A guy on ed38 has 7x18's but not lowered to be honest it looks daft.
