Golf mk1
head lining!
Topic: head lining! (Read 2086 times)
andc1
head lining!
09 June 2009, 16:44 »
hi all, will a mk2 golf head lining be able to be fitted in a mk1? i no some chopping will be needed but has anyne done this or no if it can be done?
end of the day its only material rite?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: head lining!
09 June 2009, 17:37 »
possibly but it'll take a lot of hacking! main issue is the mk1 is held up with wire hoops, wheras mk2 is help up with plastic clips thru the panel and all the ahndles and rubber seals etc.
ian007miles
Re: head lining!
09 June 2009, 18:10 »
buy a new 1 from newton comercial there only £75 and it comes with instructons i done mine 2 weeks ago its not that hard
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Wayne
Sir Postalot
Re: head lining!
09 June 2009, 20:44 »
^^As above, newton is a much better bet.
andc1
Re: head lining!
09 June 2009, 21:56 »
are they ok from then then? good quality?
Wayne
Sir Postalot
Re: head lining!
09 June 2009, 23:32 »
Quote from: scoobygolf on 09 June 2009, 21:56
Yes all the classic guys use them.
andc1
Re: head lining!
Reply #6 on:
12 June 2009, 20:43 »
looked at the mk2 head linning today for my mk1, cant see why it would be that dificult to put in?!
Golf mk1
head lining!
