Author Topic: thermo time switch  (Read 3107 times)
Offline ian007miles
thermo time switch
« on: 07 June 2009, 20:47 »
hi can any one tell me i have a mk1 golf gti 1800 1983 A redge, on ther thermo time switch in the top of the coolent pipe it has 2 wires that go to it can any one tell me what wire gos to wot pole because i havent got the block connector that gos to it. one wire is white and green the other is red and black   [-_-] this is sort of wot it looks like :wink: the line at the bottom is it bit that sticks out so you cant put the connector on the wrong way round. thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Re: thermo time switch
« Reply #1 on: 08 June 2009, 08:20 »
red/black goes to pin G, wht/grn goes to pin W if the switch has pin numbers on? if not I'll look later.
Offline ian007miles
« Reply #2 on: 08 June 2009, 14:00 »
alrite mate no there arnte any numbers or markins on it
« Reply #3 on: 08 June 2009, 16:50 »
right if you look at the thermotime switch from above with the sticky out peg bit at the bottom, the red/black wire goes to the right hand pin :)
Offline ian007miles
« Reply #4 on: 08 June 2009, 17:02 »
cheers mate r u 100% on that lol
« Reply #5 on: 09 June 2009, 10:16 »
well it was on my 16v MK1 :P
