Author Topic: Sump nut & washer  (Read 7121 times)
Offline Ady TDI
Sump nut & washer
« on: 03 June 2009, 17:13 »
Anyone know where i can get a sump nut & washer from? my car has just been serviced and a new nut & washer used but would like to by another just incase.
ANywhere apart from VW's themselves as there isn't one local
« Last Edit: 03 June 2009, 18:02 by Ady TDI »
Offline Steve_PD
Re: Sump nut & washer
« Reply #1 on: 03 June 2009, 20:22 »
GSF, eurocar parts  :undecided:
Ive never changed the sump plug when I service mine, I've done 4 now
Offline Ady TDI
« Reply #2 on: 03 June 2009, 22:35 »
Thats good to hear, i heard the nut threads itself so cant be used again
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 03 June 2009, 22:37 »
you should have as the plug isn't reusable
you'll also want a torque wrench for re-fitting as the sump is aluminium and being ali it's very easy to strip the thread.
if you haven't a GSF there are loads on ebay
Offline Steve_PD
« Reply #4 on: 03 June 2009, 23:28 »
Whys the sump plug non reusable? if its not why is the sump reusable as surly the thread in the aluminum is weaker than the thread on the plug  :huh:
Offline Ridg
« Reply #5 on: 04 June 2009, 09:09 »
not sure probably something to do with the washer being integrated into the plug.  I was told that you can't reuse it by a VW master mechanic, and for the sake of £2 i'd rather replace it.
Offline T_J_G
« Reply #6 on: 04 June 2009, 10:48 »
Yeah but when you do as many services those £2's add up :wink:
Offline jettagolf
  • Mk2 Golf GTI
« Reply #7 on: 04 June 2009, 16:40 »
our sump plug was used 8 times on our mk4 and never had a problem so saved about £16 :grin:
Offline Kerrse
« Reply #8 on: 09 June 2009, 13:24 »
My car gets serviced by a ex-vw mechanic and he has never asked me to get a sump plug when he services my car. My next service it due in a couple weeks all i have to get is
Fuel filter
Air filter
Pollen filter
Oil filter
Offline Steve_PD
« Reply #9 on: 09 June 2009, 13:50 »
Fuel filter
Air filter
Pollen filter
Oil filter
Thats what I do every service
