Author Topic: old 2x2 vag com  (Read 2924 times)
VeeDubGTI16v
old 2x2 vag com
« on: 03 June 2009, 09:11 »
has anyone on here got one that i could plug into my corrado? it has an abs fault that id like to identify before i start buying expensive bits  :laugh:
within 50 miles of guildford would be great
cheers
mark
Offline AudiA8Quattro
Re: old 2x2 vag com
« Reply #1 on: 03 June 2009, 09:55 »
I've got one.
They are however very cheap to buy.
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #2 on: 03 June 2009, 09:58 »
ooh, might get my own then!
do you have a link? i have only found the conversion leads so far to use on the newer vag coms
Re: old 2x2 vag com
« Reply #3 on: 03 June 2009, 10:07 »
Yeah i think they are all like that.
Sometimes they sell both together.
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #5 on: 03 June 2009, 10:45 »
would this work on an old skool corrado 9a tho, i was under the impression they didnt work on the vag-com software?
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #6 on: 03 June 2009, 11:04 »
its getting used on my g60, not 9a engine. apparently you can fault find just the abs system on the g60's. im assuming that as a conversion cable is available then the software will work with both connection types.
Re: old 2x2 vag com
« Reply #7 on: 03 June 2009, 11:34 »
ah ok, point still stands tho does old skool g60 diagnostics work with vag-com?  i thought you had to use the old led method  :undecided:
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #8 on: 03 June 2009, 11:57 »
dont know! ill have a butchers on the corrado forum
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #9 on: 03 June 2009, 16:43 »
yep it works apparently!
