Author Topic: old 2x2 vag com  (Read 2934 times)
Offline AudiA8Quattro
Re: old 2x2 vag com
« Reply #10 on: 03 June 2009, 21:43 »
so would these 2 do the job? might as well get the hong kong stuff as im no rush.
http://cgi.ebay.co.uk/OBDII-OBD2-VAG-COM-VW-AUDI-2x2-Pin-Adapter-OBD-Cable_W0QQitemZ220376918970QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item334f7cebba&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A2|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
http://cgi.ebay.co.uk/USB-VW-Audi-Diagnostic-Car-Code-Reader-vag-com-OBD2-OBD_W0QQitemZ220372342088QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item334f371548&_trksid=p3911.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
i didnt realise it was so cheap!
That's the seller i used. Good quality stuff.
You can use vag-com on any vw with a obd port.
They even work on 1993 polo's.
I also used mine on a 1990 Audi.
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #11 on: 12 June 2009, 09:41 »
did you get yours working without much fiddling?
im currently working my way through this lot lol
http://www.audizine.com/forum/showthread.php?t=158766
Re: old 2x2 vag com
« Reply #12 on: 13 June 2009, 22:48 »
Mine worked straight away. What trouble are you having? Which VAG-com version are you using?
Offline Horney
Re: old 2x2 vag com
« Reply #13 on: 14 June 2009, 00:24 »
Oooh you can hook this up to my rado and see what it says!
Nick
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #14 on: 14 June 2009, 09:11 »
its getting it to connect to my laptop thats the problem. i think i need to play with the ports in device manager, but havent really played with it yet.
nick it might say why your abs is buggered, but thats about it!
Offline Horney
Re: old 2x2 vag com
« Reply #15 on: 14 June 2009, 09:12 »
That's OK, better than nothing :-)
Nick
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #16 on: 14 June 2009, 09:15 »
its giong nowhere near jords, i think it might burst into flames  :laugh:
Re: old 2x2 vag com
« Reply #17 on: 14 June 2009, 12:07 »
Is it not communicating at all? or is it when you tried to select a module?
VeeDubGTI16v
Re: old 2x2 vag com
« Reply #18 on: 14 June 2009, 12:31 »
you know when you select the port when you set it up, none of them connect, including the usb option
the solution is in the thread i posted above, i just havent gone through it yet! think i have to manually number the port or something. its probably my crappy laptop
