Author Topic: 1.8 Turbo hesitating  (Read 944 times)
Offline Owen
« on: 01 June 2009, 17:58 »
I have a 1.8T fitted in a mk2 Golf. However when warm and only warm it will hesitate and stutter. This will happen at a constant speed and revs and also under acceleration. The exhaust will also pop on lift off shortly after the stuttering.
Any clues on the source of the problem?
Offline topher
  • Administrator
  • fully functioning
Re: 1.8 Turbo hesitating
« Reply #1 on: 03 June 2009, 02:46 »
Check the mk4 maintenance & info section for common faults. Likely culprits for your problem are temp sender and maf sensor.
Offline Owen
« Reply #2 on: 03 June 2009, 22:17 »
Thanks, i didnt know there was a common faults section.
