Author Topic: vac line internal diameter?  (Read 1800 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 31 May 2009, 12:05 »
anyone know the size of the internal diameter of the vac lines on the FPR/DV on a 1.8T? All I can find is reference to diseasels
Offline Rhyso
Re: vac line internal diameter?
« Reply #1 on: 31 May 2009, 12:15 »
OD is 4mm isn't it?? so ID should be around 3.8mm  :undecided:
Offline golfgar
  • Audi A6 estate/subaru wagon
« Reply #2 on: 31 May 2009, 12:17 »
i bought 3mm to do my n249 bypass,fits dv and fpr like a glove :grin:
Offline Waffs1984
  • Spacers are for chumps...
« Reply #3 on: 31 May 2009, 19:14 »
So did I... tight as a nun's c**t on the N112 and 1-way valve though!
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline Voodoo-Music
« Reply #4 on: 31 May 2009, 19:24 »
Original is 4mm but you can use 3mm with no issues and from my searching and forge 3mm can be better. I'm using 3mm now and it's fine
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 31 May 2009, 20:44 »
looks like I'll be getting some 3mm ID hose then
only problem I found was getting it over the top of the DV. I'll order a metre 2nite so I've got some spare
Offline Waffs1984
« Reply #6 on: 31 May 2009, 21:40 »
I ordered 3m and probable still have 1m left, but always good to have some spare  :wink:
Offline golfgar
« Reply #7 on: 31 May 2009, 22:59 »
got my 3mm blue silacone from merlin motorsport at castle combe,£11 for 3 metres.forge wanted £18 for the same which included delivery
Offline james2
  • No scammers please.
« Reply #8 on: 01 June 2009, 13:36 »
4MM ID  :smug:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
