Author Topic: Flushing coolant  (Read 3388 times)
Offline maxp
  • J reg 8v digi gti
Flushing coolant
« on: 31 May 2009, 09:42 »
Planning on flushing the coolant today. Did a search but couldnt manage to find if there is a screw on the radiator that drains the coolant?
Failing that gonna have to remove the pincer clip attaching the hose to the rad.
Offline OakeyDoak16v
Re: Flushing coolant
« Reply #1 on: 31 May 2009, 10:07 »
I think it's as simple as that mate, just detach the hose from the bottom of the rad. :smiley:
Offline sparkplug
« Reply #2 on: 31 May 2009, 17:09 »
yeh thats what i did with mine , surprising how much crap is inside there  :shocked:
1986 GTI atlas grey
Offline Khare
  • The bear that khares
« Reply #3 on: 31 May 2009, 17:13 »
i need to flush coolant on the barge, when I changed thermostat so much crap came out, I didnt clean it cos I didnt have time, but it is on my to do list.
Offline JC
  • Back in the North.
« Reply #4 on: 31 May 2009, 17:15 »
is that before you see sense and get a 2 again  :lipsrsealed:
Offline Khare
« Reply #5 on: 31 May 2009, 17:17 »
you know im getting a 2 in january again  :cool: Hopefully  :undecided:
Offline maxp
  • J reg 8v digi gti
« Reply #6 on: 31 May 2009, 18:03 »
Drained it today, went to refil it with some g12++ (no idea what was in there before), and only put in about 3l before it was totally full. I don't think I may have got all the old coolant out. How bad is this? And for next time,should I run the car after I drained it to get the last bits out?
Offline paultownsend
« Reply #7 on: 31 May 2009, 18:11 »
think you have to take the stat out to drain it completely.
always good to run a hose through it to get all the crap out the head and radiator
Offline maxp
  • J reg 8v digi gti
« Reply #8 on: 31 May 2009, 22:04 »
Is it going to be ok to drive for a week before i change it?
Offline PeanutButterPiece
« Reply #9 on: 31 May 2009, 22:06 »
should be fine, keep an eye on temps in case you have air lock
