Author Topic: tim pressure gauge  (Read 2141 times)
Offline boxer1968
tim pressure gauge
« on: 30 May 2009, 00:40 »
hello again ,just wondering if any one has tim pressure gauges fitted to there cars mine had three (volts ,oil ,temp) not connected up got the volts sorted , now trying to sort out the other two ,have bought the correct sender units for them plus the t-piece .my first question is have i fitted this correctly ie tim oil temp gauge  sender unit into t-piece, than orignal temp unit screwed into t-piece as well, than screwed into oil cooler housing orignal wire is yellow on the temp unit .my next question wher do i fit the tim water temp sender unit i know i have to remove one but which one,and do i have to piggy back the wires to make both tim and mfa temp work, pics if poss thanks in advance .car is a mk2 16v on a h plate.ps sorry for the essay .max
Offline Ben Lessani
Re: tim pressure gauge
« Reply #1 on: 30 May 2009, 22:02 »
Do you mean VDO
Offline boxer1968
« Reply #2 on: 30 May 2009, 22:58 »
gauges are like the vdo ones but these are made by tim im assuming principles are the same mine are tim 034 4 oil pressure with sender tim 097 .temp pressure 035 with sender tim 099 ,t-piece i bought is a lma 050 ,hope tis makes sense now
Offline danny_p
« Reply #3 on: 31 May 2009, 00:15 »
never seen tim ones before
all the VW's have gone bar 1.
Offline DOA
« Reply #4 on: 31 May 2009, 20:47 »
Tim are just cheap gauges (no offense to the OP), do a search on google for the manufacturers website if your struggling but what you have written sounds about right although the water temperature one may need a t-piece as well if the sender is calibrated differently to the stock one. Have you tried using the stock temperature sender?
Offline boxer1968
« Reply #5 on: 31 May 2009, 22:38 »
nice one (DOA) have piggy backed my temp(TIM) gauge to stock one for now and seems to give a vauge reading compared to clocks gauge so another t-piece (and the tim sender) does seem way to go. oil one seems to be doing its job about 10 degrees out form mfa reading think i can live with that ,bit hairy today at 110 degrees but going down to 102(mfa reading) on a motorway but search says engine running about right can any one confirm this for me please for a 16v.max
