Author Topic: Fitting front strut brace  (Read 1740 times)
Offline MK3TDi1996
« on: 27 May 2009, 13:56 »
hello all,
have searched and searched the forums but can't find a fitting guide! - how should the brace be fitted? - with the bent towards to windscreen or towards the front end?
thanks
Re: Fitting front strut brace
« Reply #1 on: 27 May 2009, 14:05 »
Towards the windscreen is normal
Offline MK3TDi1996
« Reply #2 on: 27 May 2009, 14:37 »
okay great,
now then, what about the locking nuts where the bar meets the 'circle' (for lack of a better word!) - should they be tight?
It was delivered this morning without instruction so want to be sure i'm doing it right - ebay item number  350161829807
thanks
« Reply #3 on: 27 May 2009, 15:33 »
okay great,
thanks
Yes
Offline mumbles
« Reply #4 on: 27 May 2009, 16:33 »
sorry to hijack, is it worth putting strut braces on? does it make a real difference?
cheers
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline Cable
« Reply #5 on: 27 May 2009, 19:00 »
cheers
yh it does help the chassis from flexing when n under strain. they do work, most jap cars have them factory fitted.
Offline bored_Welsh_lad
« Reply #6 on: 27 May 2009, 21:55 »
front lower is the best for a golf ive been told!!! top struts can sometimes create the frontend to be too rigid and understeer a lot
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline MK3TDi1996
« Reply #7 on: 28 May 2009, 08:30 »
How true is this?
Offline Petec82
  • It may be just an 8v but it's my 8v!
« Reply #8 on: 28 May 2009, 09:52 »
How true is this?
My top struts on my lowered golf in my opinion have made the handling spot on! Goes round corners like its on rails with very little roll at all. Just my opinion but strut braces are one of those things you have to make your own mind up on. Some people love them and can't praise them enough where as others say they achieve nothing. Just give them a go my friend and let us know what you think.
Pete  :smiley:
"What do you say we kill some evil sons of b*tches and we raise a little hell!"
« Reply #9 on: 28 May 2009, 10:10 »
Going to say that on a mk3 it is a bit pointless to fit a lower one due to the subframe.
