Author Topic: Calling all gti 8v with induction kits or panel filters  (Read 4463 times)
Offline shepgti
Re: Calling all gti 8v with induction kits or panel filters
« Reply #10 on: 26 May 2009, 10:19 »
I'm gunna get a panel filter, not sure which one tho.... but does it sound alot nicer?? p.s. why would u drill your box? would it then allow crap to get in..
all performance panels will be the same so get whatever you want, drilling allows the air in faster and makes it sound much better.(as for letting crap in, a cone filter is completely open to crap....)
Offline Khare
  • The bear that khares
« Reply #11 on: 26 May 2009, 10:48 »
K&N +
:grin:
I challenge you  :laugh:
Pipercross
Drilled to death airbox
Offline christomk3gti
« Reply #12 on: 26 May 2009, 11:57 »
looks sick them holes lol, I will get a panel filter just not sure bout them holes, the idea of a filter is to stop sh!te getting in, but with the holes drilled, whats the point of a filter at all, you'l draw all sorts of crap in. hmmmm
Black 8v GTI............. Whats a Waffle Valve?
Offline shepgti
« Reply #13 on: 26 May 2009, 13:05 »
is it just me or do you not understand the concept of an AIR FILTER
Offline mbGti
« Reply #14 on: 26 May 2009, 13:09 »
umm how do you think the sh!te is going to get past the filter?
Offline GJSEB79
« Reply #15 on: 26 May 2009, 13:12 »
i agree shep i think he is missing the point of a ( AIR FILTER ) ie to filter the rubbish from going through
« Reply #16 on: 26 May 2009, 13:17 »
now now lol.... just checked my box, the air inlet pipe is at the top, so ok i agree it will stop the crap from goin through, i knew that, but as your drilling at the bottom (ie under the filter) crap can still get in through them holes? right? just confirm i'm wrong and i'll do it when i get the panel filter.
Offline mumbles
« Reply #17 on: 26 May 2009, 13:20 »
yes the crap will come through the hole but......
air goes in through holes - then through air filter - (clean air) goes through to engine.
sorted, now go do it!  :grin:
ps. khare, that pipercross filter looks badass!!
« Last Edit: 26 May 2009, 13:22 by mumbles »
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
« Reply #18 on: 26 May 2009, 13:24 »
nice one, wheres cheapest place to get the panel filter from.... as i got an 8v... are the 16v's the same for the panel filter? I'm thinkin of a piper cross one.... cheers and sorry for been bit dumb, just got up lol anyhow goin 2 work :-( 2 til bluddy 10.... or is it 2 - til when? hmm cya guyz
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #19 on: 26 May 2009, 19:04 »
Sound level increases obviously vary massively depending on how much of the LOWER section you remove, experiment with if by drilling a few smallish halls on the lower wing side of the airbox and increase until you're satisfied with how it sounds.
As for allowing extra crap into the sytem this shouldn't ever become an issue if you're only drilled the lower section as this is before the actual airfilter. Just make sure you don't drill the upper section of the airbox unless you liek you engine breathing pure dirt!
