Author Topic: Calling all gti 8v with induction kits or panel filters  (Read 4462 times)
Offline lukesgti8v
Hi people, ive tried searching for my answer but cant find one  :cry:
Ive got a agg gti 8v with the standard filter on at the moment but can't decide what to do.
Ive been looking at the pipercross air filters and panel filter as mainly i want to increse the performance abit more. So basically what im asking in terms of performance which is better a induction kit with a air feed or panel filter with a drilled airbox?
If anyone could tell improvements or losses they got from fitting either I would be very grateful.
thanks
Offline Adam
Re: Calling all gti 8v with induction kits or panel filters
« Reply #1 on: 25 May 2009, 18:20 »
I have a panel filter (Pipercross) with a drilled air box. I like it, sounds good and you can feel it slightly  :smiley:
Down Hill From Here.
Offline funkyfive
« Reply #2 on: 25 May 2009, 18:49 »
I got a Green Cotton Filter with a drilled airbox and it does the job. Remember this is a cool air feed attached to the airbox.
Offline GJSEB79
« Reply #3 on: 25 May 2009, 18:56 »
hi you no when you drill the air box do you drill the bottom half of the air box
Offline funkyfive
« Reply #4 on: 25 May 2009, 19:04 »
I only drilled on the drivers side of the airbox
Offline GJSEB79
« Reply #5 on: 25 May 2009, 19:08 »
oh right cheers was it top or bottom of air box cheers gordon
Offline funkyfive
« Reply #6 on: 25 May 2009, 19:12 »
Bottom mate
VW BUSH
« Reply #7 on: 25 May 2009, 21:19 »
K&N +
:grin:
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« Reply #8 on: 25 May 2009, 21:40 »
i have a pipercross panel filter and a drilled air box
i cut the 90 degree angle trumpet off the air box and attached some duct going to a vent on the front bumper:)
works well
i drilled the box at the bottum and the drivers side
Offline christomk3gti
« Reply #9 on: 26 May 2009, 10:14 »
I'm gunna get a panel filter, not sure which one tho.... but does it sound alot nicer?? p.s. why would u drill your box? would it then allow crap to get in..
Black 8v GTI............. Whats a Waffle Valve?
