Author Topic: Gearbox/reverse light connection question...  (Read 1312 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 24 May 2009, 17:11 »
So I've just put new engine in (SHE'S ALIVE!! *cries with joy*) and the reverse light connection is different. The wire that's in there now, that was on the old gearbox (I don't know the technical terms) is like a plug that goes into the back of a radio, and the connection on the new 'box is like 2 pins sticking out, kinda kettle lead size. Are they different 'boxes, or is it just they changed the connection, like with the speedos??
Cheers,
Rich
Offline Ben Lessani
Re: Gearbox/reverse light connection question...
« Reply #1 on: 24 May 2009, 20:44 »
The switch is just a switch - so if the connector is different, then just chop the plug off and crimp on two female spades.
Offline nealey
« Reply #2 on: 25 May 2009, 00:30 »
Just change the switches over from the old box to the new one
Obviously compare them when they are out to make sure nothing else is drastically different
Offline Ben Lessani
« Reply #3 on: 25 May 2009, 02:07 »
Just be careful swapping them over, as some are different heights - so it won't actually make contact if its too short.
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
« Reply #4 on: 25 May 2009, 20:43 »
if it's just a reverse light switch can you not just put the one out of your old gearbox into your new one??
Offline JC
  • Back in the North.
« Reply #5 on: 25 May 2009, 20:48 »
one will be a bolt in thing with 2 connectors, ?other will be an 8 pin affair ?
i off searching. BRB
Offline JC
« Reply #7 on: 25 May 2009, 21:29 »
nice find chuff, twisedblack, all you need to do now is cut the plug off the old loom with a good length of wire and then cut the appropriate wires on the new loom and join them up (how is personal preference, solder or join with electrcal connectors)
« Reply #8 on: 26 May 2009, 10:45 »
depends, there are 3 types of reverse switch.  since yours is a 90spec you had the later 2 pin one, which has a clip on connector, the earlier 2 pin ones have 2 spades. as already said,m swap the reverse switch over!  the really early ones have a large multi pin plug, this one also does the large mpg gauge and upsift light.
