Golf mk2
removing wur and 5th injector
Topic: removing wur and 5th injector (Read 1195 times)
ben harcombe
GTI forum regular
23 May 2009, 22:54 »
As above really its a abf lump using k-jet could i remove the wur and 5th injector and it still run decent not to bothered about cold starts as longas its goes eventually
Ben Lessani
The poor mans MK2 Haynes author
Re: removing wur and 5th injector
23 May 2009, 23:47 »
Don't understand why you would want to...
Removing parts isn't a way to fix a problem - its like chopping off your arm because its broken. Fix the problem, not the symptom.
ben harcombe
GTI forum regular
23 May 2009, 23:55 »
thinking of de-cluttering the engine/bay/loom just asking that's all so instead of pulling it off to find out it don't run afterwards
Ben Lessani
24 May 2009, 00:51 »
Its probably a decision come winter you'd probably regret
danny_p
Forum addict
24 May 2009, 11:56 »
wur is quite inportant
all the VW's have gone bar 1.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
26 May 2009, 10:32 »
as above cant remove them. if you dont want a cluttered engine bay dont fit k-jet! the 2.0 9a lumps had a cover over the top of the metering head, that helps a bit plus the later spec rubber injection lines help them not to stand out so much.
Golf mk2
