Author Topic: Vag Com - Beep On Lock/UnLock  (Read 10290 times)
Offline THiNK
  • Golf MK4 GT TDI 150
« on: 22 May 2009, 19:29 »
Hi - Are there any guides on how to do this please?
Bear in mind I haven't used VAGCOM other than to clear errors :)
Cheers,
CS
Offline Rhyso
Re: Vag Com - Beep On Lock/UnLock
« Reply #1 on: 22 May 2009, 19:33 »
look on www.ross-tech.com
takes longer to boot up the computer than to do do the changes
Offline Voodoo-Music
« Reply #2 on: 22 May 2009, 19:33 »
Here you go
Selective Unlocking:
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
So, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
Lock/Unlock Horn/Flash:
 [Select]
[Adaptation - 10]
Channel (03..08)
Adaptation Value (1 = on, 0 = off)
[Save]
Channel 03 Auto Lock
Channel 04 Auto Unlock
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Lock, turn signals flash
Offline Rhyso
« Reply #3 on: 22 May 2009, 19:34 »
bah you made it too easy for him  :tongue:
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 22 May 2009, 19:39 »
OHHHH !!! Rhyso is turning into a right b!tch :shocked:
Offline Rhyso
« Reply #5 on: 22 May 2009, 19:40 »
yeah bring it on  :tongue:  and add me to MSN too you miserable git  :laugh: :laugh:
Offline barry-gti
« Reply #6 on: 22 May 2009, 19:56 »
And me!!!  :smiley:
Offline THiNK
« Reply #7 on: 22 May 2009, 19:57 »
I like easy  :wink:
And seeing what someone else says always makes it easy  :smiley: Its what you are here for  :wink:
CS
Offline THiNK
« Reply #8 on: 22 May 2009, 20:00 »
Hey,
I'm guessing at the below :
Channel 03 Auto Lock - This is the thing that locks the doors at 10mph isn't it?
Channel 04 Auto Unlock - Whats this?
Thanks,
CS
Offline Rhyso
« Reply #9 on: 22 May 2009, 20:02 »
Hey,
Thanks,
CS
when you remove your key from the ignition it will unlock the doors otherwisde two pulls on the handle or hit the button on the door
