Author Topic: Vag Com - Beep On Lock/UnLock  (Read 10295 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Vag Com - Beep On Lock/UnLock
« Reply #20 on: 22 May 2009, 22:23 »
i just managed to make my vag com get into the the recode section  :smiley:
which re-code section?
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
iirc thats for one touch un-locking  :wink: i enabled that one i think with the shareware version this is the only one you can re-code and when you scan it it will tell you module is incorrectly coded i just ignore that
2000 Mkiv GTi 1.8T AGU
jamie16v
« Reply #21 on: 23 May 2009, 09:20 »
just one question though, what is the 5 digit code he mentions?..
should it be the exact same number as he mentioned or just add one to the one you have?.
jamie16v
« Reply #22 on: 23 May 2009, 14:50 »
right, that was a good guide, i know ross-tech have a tutorial but i think its a bit too in depth..
why dont we have a sticky here where we can just add the easy and cool stuff we can do?
i just did my one touch unlocking from this guide which i think is much, much better. as soon as get a full/registered version of vag com i will be doing quite a bit.. it shall be fun :smiley:
