Author Topic: Early MK2 handbrake and Mk3 rear calipers. Which handbrake cable do I need?  (Read 2334 times)
Offline ozegti
As above. The golf failed on no effort at the handbrake. So, new mk3 calipers are in the pipeline however, I don't know what cables to get to make them work.
Anyone?
use the ones on the car :)
what year is it?
Offline ozegti
A reg, 1984. Will the stock cables be long enough?
Offline Ben Lessani
Yeah, they should be fine - but you'll need to flip the callipers upside down and flip each side round, left on right, right on left.
But to bleed them, you need to remove them, chock the calliper with a piston winder and make sure the bleed nipple is pointing up. If you chock it with wood - remember that pumping the brakes is going to bite into the wood and it will be a b!tch to remove.
Read this http://www.golfgtiforum.co.uk/index.php?topic=49436.msg1000233#msg1000233 and this http://www.golfgtiforum.co.uk/index.php?topic=49436.msg979860#msg979860
Offline frybert
yer the early handbrake cables are abit longer, there the ones u use when doing a mk4 caliper conversion aswell :cool:
no you dont, you only use the ones for your car. if its a post 87 you use post 87 cables, if its pre87 you use pre-87 cables. as ben says if you want to fit post 87 calipers to a pre87 car you need to mount them upside down. reason for this is post 87 the handbrake lever on the caliper was moved, and the handbrake lever design changed.
you cant just swap the cables as they end up way too long or way too short, as the lever itself is very different.
