Author Topic: Induction kit has broken a sensor, can anybody identify this pls?  (Read 2134 times)
Offline deanjames
Hi
The bracket has snapped on my ill fitting induction kit and has in turn broken a sensor.
Engine warning light has gone yellow so i'd like to replace the part, I think it's the cam timing sensor but not sure.
Can anyone assist? thanks in advance
Dean
(sensor is on the right handside in the bend)
« Last Edit: 21 May 2009, 20:31 by deanjames »
Offline bacillus
what make intake is that as the diameter at the MAF area looks larger than stock and this can lead to the car running too lean.
« Last Edit: 21 May 2009, 20:38 by bacillus »
Without traction power is nothing!
Offline deanjames
The intake is made by HPS, car has run fine with it on for over 8k miles and sounds great.
Just a shame the fitment is crap, I'm probably going to have to go back to the original airbox unless I can make a new bracket.
Offline AlanD
  • MK5 2.0T 16v
That a fking massive intake :shocked:
What happened inside your bonnet? In the last pic it looks like a mud bomb has exploded inside your engine bay.
You know anyone that has VAGCOM? That will tell you what the problem is if the engine management light has come on.
Offline deanjames
It's just water and mud from driving through big puddles!
I don't really need a VAGCom because i can see which sensor it has broken (the filter pipe is resting on top of the broken sensor and snapped the cables off the top.
The filter pipe should sit higher but the bracket that holds it up was crap and broke
Offline deanjames
So nobody knows what sensor this is????!!!
pls help guys, i'm sure it the cam timing sensor but need somebody in the know to confirm!
thanks
Offline TomB
If ETKA was working on my laptop I'd tell you in 5 minutes :(
Is there not a visible part number on it?
Tom
MK5 Golf GTI in Tornado Red
Offline deanjames
Hmm no visible part number and also cant see how i'd get the damn thing out!
