Author Topic: Aerial Problem  (Read 5054 times)
Offline funkyfive
Aerial Problem
« on: 19 May 2009, 21:37 »
I have just installed a Alpine CDE-9881R but the aerial does not fit, can any one help or advise?
Issue number 2, does anyone know how to wire up the electric aerial?
« Last Edit: 20 May 2009, 08:34 by funkyfive »
Offline Adam
Down Hill From Here.
Offline funkyfive
Re: Aerial Problem
« Reply #2 on: 19 May 2009, 22:01 »
You will need either -
http://www.caraudiodirect.co.uk/aerial-adaptor-p-210.html?cadid=hse9og47ihqs6ebnbs4sefbgc2
or
http://www.caraudiodirect.co.uk/aerial-adaptor-p-4054.html
Option one looks good
But what does this mean on there website?
"Aerial adaptor converts original aerial on VW & Vauxhall vehicles to standard aerial plug.
IF YOU ARE USING ON VW OR SEAT THEN YOU WILL ALSO REQUIRE E118 AERIAL ADAPTOR"
Offline Shady Pioneer
  • graphic designer.
Re: Aerial Problem
« Reply #3 on: 19 May 2009, 22:01 »
You need the second link from the above post chap. I have the 9880R, I'm taking it is the same connection for both of us, I needed the black lead :)
Offline funkyfive
Re: Aerial Problem
« Reply #4 on: 19 May 2009, 22:06 »
Hi shady, does your car have the electric aerial?
Offline funkyfive
Re: Aerial Problem
« Reply #7 on: 19 May 2009, 22:10 »
Done cheers for that i got it from Ebay £1.99 including delivery. Dancer
DIN TO ISO AERIAL ADAPTOR
  • graphic designer.
Re: Aerial Problem
« Reply #8 on: 19 May 2009, 22:12 »
Nah mine is actually a windscreen mounted aerial, that has the silver long pin at the end, that goes into the long black bit of that adaptor and the circular bit goes to the headunit :)
Not a bad price either at £1.99 delivered :) I paid £6 for mine :( from Halfrauds lol!
Offline funkyfive
Re: Aerial Problem
« Reply #9 on: 19 May 2009, 22:21 »
What sound system have you got setup?
This is want i am thinking about getting
2 x infinity Reference 6522si for the doors
1 x Infinity 7 x 10 for the back shelf
1 x 12inch JL Audio Sub
2 x Alpine V12 Amps
