Author Topic: Car lost power??  (Read 1088 times)
Offline Bucky
Car lost power??
« on: 19 May 2009, 14:17 »
 For lunch today i decided to take a trip to the better halfs for a bit of lunch . . jumped in the car and noticed a lack of power, when i put my foot down it was like the car was back to standard (its re-mapped) and i couldnt hear the turbo hardly at all.
 Then on returning to work it was back to normal with full power all fine?? i do no that my MAF sensor is messing around and im getting a new one this friday, but would this of caused the drop in power?
 Im a bit confused  :sad:
GTI me up !!!
Offline Phil18t
Re: Car lost power??
« Reply #1 on: 19 May 2009, 14:47 »
this happened to me once after removing my battery to fit the carbonio cai, on my way home after fitting it at work noticed mine wasnt boosting the same n was a lot slower, went in my house for 5mins came bk out n tried it and it was alrite and not not done it since..touch wood. thought i'd wiped the map from diconnecting the battery!lol
Offline Voodoo-Music
« Reply #2 on: 19 May 2009, 14:55 »
Soudsn like that maf being intermitant.
You will prob have a fault code 16486 for the maf which would be good to check if you have vag com. The car will reduce the power due to not knowing the correct intake
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 19 May 2009, 21:06 »
i have this, you will prob find you will have a pressure drop between turbo and throttle valve.
Offline rheady
« Reply #4 on: 19 May 2009, 21:26 »
Might be worth cleaning the throttle housing
