Author Topic: External Temp Gauge Problem  (Read 1746 times)
Offline danowen49
« on: 19 May 2009, 00:29 »
Hi All
I am new to the forum as I have only owned my GTI mark V for about 4 weeks but already I have encountered a few problems.... the main one being no aircon - the car is just out of warrenty and i didnt buy it from a dealers so from reading everyones posts on the issue I could be a bit screwed if it's a compressor or something..... But I'll get a service done 1st and see what happens...
Anyway - the digital temperature guage reading the external temp has never had a reading.... has anyone else encountered this problem/ know a solution? its nothing major but would just like to know if its something simple....
cheers
Offline bacillus
Re: External Temp Gauge Problem
« Reply #1 on: 19 May 2009, 08:15 »
The temp sensor is behind the bumper. It's most likely disconnected or needs replacing.
Without traction power is nothing!
Offline Gene Hunt.
« Reply #2 on: 19 May 2009, 10:51 »
Hope the aircon is just a simple service mate  :shocked:.
Candy White ED35.
Offline ub7rm
« Reply #3 on: 19 May 2009, 12:25 »
The two issues may be related... The air con won't activate if the external temp is below 5 Deg C to protect the compressor etc so if the system realises the external temp sensor is beefed the A/C might be deactivated to protect itself as well....
Hopefully this is the case as it would be an easy / cheap DIY fix  :smiley:
2020 BMW 128ti
2017 Golf GTD Estate
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 19 May 2009, 12:35 »
10 points to that man, good thinking.
Offline ub7rm
« Reply #5 on: 19 May 2009, 18:46 »
Not just a hat rack my friend  :grin:
2020 BMW 128ti
Offline TagnuT
  • Edition 30
« Reply #6 on: 19 May 2009, 20:26 »
I'd try that first... :smiley:
Bye Bye Edition 30
Offline danowen49
« Reply #7 on: 20 May 2009, 14:48 »
thanks a lot for all your responses... sounds logical that the 2 are connected. With regards to the temp sensor - i am assuming its the front bumper.... any ideas what side and if its easy to get too?
this maybe a job for the weekend!!
Offline Rhyso
« Reply #8 on: 20 May 2009, 14:51 »
passenger side behind one of the grilles i believe.  Thats where it is on my MK4 so i assume its on the same place  :undecided:  don't quote me on that though  :grin: :grin:
