Author Topic: Broken trim clips - solution?  (Read 1376 times)
Offline Waffs1984
  • Spacers are for chumps...
« on: 18 May 2009, 22:03 »
Hi all,
OK so when removing my tasty walnut trim to spray it the clips on the black bit of the dash behind simply disintegrated when i CAREFULLY pried the trim off! I have put blobs of blu-tac in the holes where the clippy bits should be but the passenger side long strip keeps falling off whilst driving - anyone any ideas on a better solution for holding the bugger(s) in?
Cheers,
Matt.
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline northeast_gti-t
  • "1.8T AGU"
2000 Mkiv GTi 1.8T AGU
Offline Ridg
  • TDI - Soot Happens!
Re: Broken trim clips - solution?
« Reply #2 on: 18 May 2009, 22:13 »
your only real options are glue, i think trim tape will be too thick or buy a new cage (the bit you've broken (see pic)).
personally i'd glue them, with a very thin layer as not to get any excess round the side, as other than removing them to spray paint or swap for R32 / ani peices there is no need to ever remove them again.
Offline Voodoo-Music
« Reply #3 on: 18 May 2009, 22:18 »
Mine did this when i changed to the anni dash and i used a thin bead of black silicon to bond the new ones on. Grabbed tight but can be pulled back off with a little force if needed
Worked for me as its not a permanent fix but will last till you dont want it too
Offline Waffs1984
« Reply #4 on: 18 May 2009, 22:57 »
Cheers for the replies guys! Yeah basically it never needs to come again now i've sprayed it as i'm not planning on splashing out over £100 on trim lol! May go for the black silicone option me thinks...
Cheers,
Matt.
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
« Reply #5 on: 19 May 2009, 18:30 »
is there a how to guide on how to remove these without breaking them??? anyone!!!
...Burn Rubber...Not Your Clutch...
Offline hainesz
« Reply #6 on: 21 May 2009, 17:32 »
well anyone know???
