Author Topic: 8v gti head gasket(vw vs unipart/euro/gsf)  (Read 2356 times)
Offline parrotveasey81
« on: 17 May 2009, 21:46 »
just blew my head gasket today in between 1 and 2 only on compression :angry: :cry: :sad: :angry:
car is a e reg 1.8 8v digi
first off what i want to know is in what order and how tight do i do the head bolts up
now this one will get some of you going
what i need to know is what parts i can buy cheap and what parts i have to buy from vw
my list is something like this(i may miss some stuff out that needs to be in the list,so any thing you can think of would be good)
head gasket
inlet gasket
exhaust gaskets(will be fitting a ashley 4-1 manifold)
head bolts
coolant
cam cover gasket
thermostat and gasket
blue temp sender
think thats it(mind gone blank now)
cambelt is only 3 months old so should be ok
drive it like u stole it,brake it then mod it
Offline Conker
Re: 8v gti head gasket(vw vs unipart/euro/gsf)
« Reply #1 on: 17 May 2009, 21:53 »
head gasket
coolant
cam cover gasket
blue temp sender
I would get the above from VW as they are critical parts and almost the same price as any other brand.
I got my head bolts etc. from http://www.vwspares.co.uk/golf2.php, the remainder from ECP of GSF.
As for bolt tightness etc, seriously buy a Haynes manual - its section on head gasket replacement is really good and worth the £10 it will cost you off ebay.
Offline danny_p
« Reply #2 on: 17 May 2009, 21:56 »
torques normaly come with gasket and depend on the gasket tbh  btw you really shoudl use new bolts yours will be quite old by now
all the VW's have gone bar 1.
« Reply #3 on: 17 May 2009, 22:10 »
thanks conker by the looks of it i might just get it all from vw as what i would save on parts it would cost me in fuel.
danny.p i did put head bolts on my list as when i do work like this i try to replace as much as funds allow.
any one think of anything else that i need to get
has any one got a ashley 4-1 and are they any good
i would buy a haynes but as danny.p said it depends on the gasket(will talk nicely to vw and see what they say)
Offline Conker
« Reply #4 on: 17 May 2009, 22:58 »
N.B.   Remember that theres an order to tightening the bolts up too.
Offline danny_p
« Reply #5 on: 18 May 2009, 02:28 »
the normal torqueis are  40nm   60 nm  then 180 degrees.     ( for composite gasket  a lot are mls now )
pattern is
(10)     (4)       (2)      (6)      (8)
(7)       (5)       (1)      (3)     (9)
« Reply #6 on: 18 May 2009, 08:16 »
thanks danny p most helpful.
will be going to vw today to order the parts.
Offline dirtydub
« Reply #7 on: 18 May 2009, 11:29 »
i have an ashley 4-1 and full system
very happy with it to be honest. pretty cheap and not bad quailty although the welding is a little poor.
makes a good sound without being to noisey and had slight power increase after fitting it.
originally got a stainless hottuning manifold which didnt fit at all but the ashley fitted spot on.
Rich
'86 golf gti 8v k-jet project up and running :)
Offline Reasty
  • Alpine white valver.
« Reply #8 on: 18 May 2009, 11:40 »
Ive got an ashley four branch on my 16v,went on without any trouble at all and really makes a difference to the 16v and the way it pulls through the rev range also sounds awesome on a 16v so imagine it would be the same for an 8v,it was about 2 hundred odd quid and that was some time ago but im very happy with it.
« Reply #9 on: 18 May 2009, 18:17 »
went to vw to day and walked away £169.57 lighter,parts should be hear on wednesday.
so the ashley manifold is the one to go for(good job i looked on hear first before i went and brought one of ebay)
guess i will have to find someone who has got one in stock and can get it to me by Thursday as rally design will take a week to get one
