Author Topic: leaking!!  (Read 1353 times)
Offline gavharris
leaking!!
« on: 15 May 2009, 17:34 »
After the glorious weather today i got in my car after work and noticed a puddle of water in the passenger
side footwell, not massive just a bit of water. there seemed to be water collecting under a cover near the tray!
just wondering if this was common on the mk2's??
Thanks
G
Offline frybert
Re: leaking!!
« Reply #1 on: 15 May 2009, 17:39 »
yes there is a mesh grill under the scuttle tray on the passenger side of the engine bay, does the scuttle tray cover it properly? or is it cracked?
Offline Khare
  • The bear that khares
Re: leaking!!
« Reply #2 on: 15 May 2009, 17:43 »
Mine used to do this.
Either the scuttle panel leaks and water drops directly into the fan like mine was doing, or it falls on the bulkhead and just drips into the fan housing through the base of the grill.
To fix the leak from scuttle panel its either new scuttle panel that doesnt leak, or bodge it with plenty of silicone.
To fix the leak from the base of the mesh grill then you have to remove the mesh, clean up the area well, then using silicone seal the mesh grille to the bulkhead.
Offline Ben Lessani
Re: leaking!!
« Reply #3 on: 16 May 2009, 19:35 »
Doesn't sound common at all - last time I saw a MK2 with water in the footwell, it was catastrophic chassis and floorpan damage.
I've have the car immediately scrapped if I were you.
http://www.matey-matey.com/leak_prevention.shtml
Offline johnson6672
Re: leaking!!
« Reply #4 on: 16 May 2009, 20:48 »
Take the scuttle panel off and clean the drain holes in the corners, common fault on lots of cars, drain hole blocks and water comes in though the heaters, had this on my old mk2, i found out the hard way that they were drains after i cleaned the leaves then filled with silicon, oops. aslo had the same problem on a focus and have heard about it on other cars!
The drain hole is normally full of leaves and stuff like that.
Hope this helps!
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
