Author Topic: My golfs list of problems *can a mod move this please*  (Read 1817 times)
Offline samjac68
hi all, this is my list off issues on my 1.3 project car.
driver side sill
Its got several holes, biggest is 5cm or so span, my plan here is to make a plate to fit over all the rust, fill the inside of the sill with waxoyl underseal and have the plate welded on, underseal that and fit gti sill covers, or the stickers that come on certain golfs that cover the sills?
drivers side jacking point
this is rusty and falling apart, its not an actual hole in the floor so will it pass mot??? hopefully will form something to weld over it, and underseal.
carb
Car does start easily but is lumpy and ticks over low, it does badly need a service (which will be done after mot) the carbs on these are crappy? is it a good idea to strip and clean it? is there a service kit available?
cambelt
Cambelt was done at 62k and car is now at 110k, time to be changed??? never done a cam belt before but im gonna get a haynes manual some time this week
sunroof
my sunroof has been sealed with bathroom sealant, read somewhere it might just be drain holes blocked, ill check these, get a new seal, spray the surround and cut away all the old seal?
Engine mounts!!!
main worry... the engine on tickover wobbles the car really badly, the front mount is very rotten, the left mount (as looking at it from the front) the engine wobbles in the rubber and the car stays still. im sure it isnt normal, anything else these can be or is it just a case of change them all?
brake pipes
all brake pipes on the car appear a bit corroded, whats the point where mr mot tester says 'theyre bolloxed'? replumbing the brakes sounds expensive, havent a clue how to go about it :huh:
i know this is a major list but any help id apprechiate it :smiley:
sam
« Last Edit: 13 May 2009, 08:53 by samjac68 »
Not got a golf yet! did have a 1.6 driver plan to have another project car soon ;)
Offline Ben Lessani
Re: My golfs list of problems, cause for concern on a few?
« Reply #1 on: 12 May 2009, 23:59 »
You've posted this in the wrong category boss!
driver side sill
Have a look here http://www.golfgtiforum.co.uk/index.php?topic=49436.msg979860#msg979860 . You can either make a plate to fit - or just buy an outer sill cover from ECP. You might be better off with the latter so at least it follows the curve of the bodywork better.
You need to cut back at the rot and get to good fresh THICK metal, otherwise you'll be chasing your weld for ages!
The jacking point is the sill? If you have a hole in the floorpan, cut it out again and weld a fresh plate in. If the hole is in the chassis leg (the only other place I could think of jacking from?), then I wouldn't even bother with the car.
cambelt
If the car is new to you, change the belt, its a 20 min job. Jack it up on the drivers side, support with an axel stand under the chassis leg. Remove the wheel, loosen the PAS belt (http://www.golfgtiforum.co.uk/index.php?topic=49436.msg877119#msg877119) then loosen the aux belt from the alternator by loosening the 6mm allen pivot bolt and the 13mm toothed wheel. Remove the crank pulley, then the timing belt cover. Mark the crank in relation to the block, belt and aux shaft, mark the cam shaft in relation to the head and the belt. Line your old belt up against the new one, copy the markings over, then line up the new belt on the car as per the markings, fit it, turn the crank and cam slightly away from each other to tension the front face of the belt, then tighten up the tensioner on the reverse.
sunroof
It could be a few bits, there is 4 drain hoses, the front two run down the A pillars and exit between the door and wing. If the wing has ever been replaced, you'll find the drain hose is probably trapped. The rear ones run down the C pillar on each side again, and pass through the inside of the boot behind the carpet next to the rear clusters and exit at the back of the rear quarter panels.
Shoving a straightened out coathanger down the front tubes should unblock them nicely, the rears are harder, I found hoovering the entire inner skin on the boot did wonders - theres lots of little rusty bits kicking about blocking stuff up. Another good trick - is to get a foot pump/air line, connect it to the exits of the tubes (works on both front and rear) and blast it hard a few times - hundreds of crap will fly out.
New seals are about £40 each though (inner and outer). Make sure you actually have all the parts fitted on the sunroof - mine was missing bits (hence the leak) http://www.golfgtiforum.co.uk/index.php?topic=49436.msg392131#msg392131
Engine mounts!!!
IIRC the general consensus (short of solid mounts), is to use 1.3 front and g/box mounts, with the original block mount
brake pipes
Brake pipes are easy to make, but you need the right tools. A cheap flaring tool will do you no favours, so expect to spend about £50+ on the tool alone. Pipe, fittings and fixings can be found anywhere, if you're doing the whole car, then you'll need a good few meters of hard line. Scroll halfway down this post (http://www.golfgtiforum.co.uk/index.php?topic=49436.msg979860#msg979860). I would also suggest in investing in a brake line spanner too.
The rubber unions can be replaced, you need 6 of them on a rear disk version. TSR sell a full steel braided kit for about £60 if memory serves. Replacing the unions really depends on wear though, they'll outlast the hardlines by a fair whack.
« Last Edit: 13 May 2009, 00:11 by Ben Lessani »
Offline samjac68
« Reply #2 on: 13 May 2009, 07:46 »
cheers for the reply :smiley:
wrong section though? its all maintanence and its posted in the mk2 maintanence forum :huh: or do you just mean the welding bits ive posted? my bad  :sad:
ill probably get an outer sill cover, just gotta speak to my welding friend up the road and see if hes ok with welding it :smiley: i was initally going to fibreglass it but would rather do it properly.
I noticed on your project page youve made some new brake lines, do you need a special tool for this (i remember someone saying something about a flaring tool) or do you just buy it at autofactors and bend away?
cheers
sam
Offline Ben Lessani
« Reply #3 on: 13 May 2009, 08:05 »
This section is for tutorials, not discussion ;)
For your brake likes, as said, you need a flaring tool. You remove the old line, straighten it out, get a length of new line the same length. Fit the flare nut (the right way round), then flare the pipe. Put the pipe to the car and gently bend it to shape, then thread in the pipe into the fittings.
I suggest doing some reading about it, you don't want to mess around with brake lines if you don't have the experience.
Offline samjac68
« Reply #4 on: 13 May 2009, 08:52 »
oops :sad: can a mod move this to the appropriate section :smiley:
yeah ill make sure i know what im doing before i tear all the brake lines out lol :smiley: so flaring is to join the pipe to the fitting to seal it either end, and i bend the pipes by hand? im actually doing plumbing at college at the minute but i think 15mm pipe will be a bit too wide :huh:
here are my current brake lines-
definately shagged? :huh:
