Author Topic: Whats The Best Induction Kit For 8v gti hitachi maf  (Read 6112 times)
Offline hicksy13
Whats The Best Induction Kit For 8v gti hitachi maf?
Offline Mikester
  • Civic Type R
Re: Whats The Best Induction Kit For 8v gti hitachi maf
« Reply #1 on: 12 May 2009, 19:34 »
KN or Pipercross are the reconised brands for induction kits.
Swing + Roundabout = This question.
One of the two will do mate. Now there will be 100 replies on how you should drill your air box, make cold air intakes, and slagging of heat soke etc.
Offline Adam
« Reply #2 on: 12 May 2009, 19:34 »
 :lipsrsealed: :rolleyes:
Get a pannel filter and drill the air box (I.e drill big ish holes on the BOTTOM section of your air box)
The problem with a Induction kit is it is open, prone to heat soak. If you relly want an induction kit go for a closed type but they can cost £$£$
EDIT: Mikester is too fast for me
Down Hill From Here.
Offline Khare
  • The bear that khares
« Reply #3 on: 12 May 2009, 19:37 »
Drilled airbox
ONLY on rear/wingside/front
NOT on the engine side.
and
Pipercross panel filter
= happy khare
Unless you want to spend circa £200 on a closed induction kit like a BMC, then just buy a decent panel filter, and modify the airbox.
Offline Mikester
  • Civic Type R
« Reply #4 on: 12 May 2009, 19:38 »
Told you so..... Drilling airbox was an idea though up by someone who couldnt afford an induction kit.
Heat soke was made up by non gti owners.
I'll get my coat. lol
Offline Adam
« Reply #5 on: 12 May 2009, 19:41 »
Leave.....now!
You think its a myth!?
Get it....now leave!
Hey its a cheaper way! Works dosn't it!
Offline hicksy13
« Reply #6 on: 12 May 2009, 19:42 »
heat soak doesnt worry me as can make a stainless cover for it at work
just miss the sound of an induction kit after listening to a 306hdi knocking for 18 months
first golf and loving it
Offline Khare
« Reply #7 on: 12 May 2009, 19:43 »
my drilled box and piperX filter is loud, very loud. I can be heard coming frm quite a distance.
Offline Adam
« Reply #8 on: 12 May 2009, 19:45 »
Drilled boxes are loud aswell but for grunt there is not substitute for an induction.
Offline Khare
« Reply #9 on: 12 May 2009, 19:48 »
Only if that induction set up is shielded from heat and has suitable cold air intakes.
