Golf mk2
got a problem help!!!!
Topic: got a problem help!!!! (Read 1555 times)
buzz2511
11 May 2009, 22:05 »
when i picked up the my golf i notice that the rev counter is not working and now the mpg counter is not working!!
has anyone got any ideas?
thanks
white 1989 golf gti
mcchriswood
Re: got a problem help!!!!
11 May 2009, 22:25 »
to put you at ease my mpg reads 8 lol dont worry just drive
o and my rev counter bounces around before it settles
Village Idiots
GTI forum regular
12 May 2009, 07:14 »
Often this is due to the wires on the coil being the wrong way round.
Ben Lessani
The poor mans MK2 Haynes author
12 May 2009, 09:18 »
Ground wire on rocker cover ... +ve feed off coil dropped off, loose vacuum feed to MFA, duff clocks, duff MFA
Andy!
VR6
12 May 2009, 14:39 »
Yep, check all your vacuum lines, theres a handy chart on the slam panel that shows where they should be. Mine ran like poop and had the mpg issue until I sorted the vacuum system out.
buzz2511
13 May 2009, 15:14 »
great thanks guys!!!
one stupid question though where does the other end of the vacuum pipe go?
white 1989 golf gti
Ben Lessani
Reply #6 on:
13 May 2009, 15:17 »
Clocks > intake manifold
buzz2511
Reply #7 on:
13 May 2009, 16:23 »
cheers mate
check all that and things look ok there!!! just notice that the clock on the cluster is not keeping the time aswell should i change the lot??
white 1989 golf gti
Golf mk2
