Author Topic: Mk 3 16V Loss of ignition  (Read 1148 times)
j sizzle
« on: 10 May 2009, 21:48 »
Hi,
I've got an 97 Mk3 16V with a pain of a problem. The oil temp goes up to about 96 (which I believe is too high) and then the revs will flucuate and ignition is totally lost (I know this because someone connected a VAG diagnostic scanner to it). Once things have cooled down a bit it is fine to drive again. Has anyone had a similar problem? The crank sensor has been recently changed. My local specialist is at a bit of a loss to explain the problem.
To be honest it's doing my swede in a bit especially as I've only had the car for a few weeks and can't use it properly. Any help or suggestions (apart from selling it!!) would be much appreciated. Cheers
Re: Mk 3 16V Loss of ignition
« Reply #1 on: 10 May 2009, 23:27 »
Not sure on your problem but 96 is not that high, my 8v always was around 95
Offline danny_p
« Reply #2 on: 11 May 2009, 01:43 »
fluctuating revs is normaly cranck sensor.    possoblity of it been hall sensor in dizzy.
is it misfireing at all ?  if it is chould be the coilpack
all the VW's have gone bar 1.
« Reply #3 on: 11 May 2009, 08:41 »
when you say ignition is lost, do you meanengine spark cuts out or you loose ign live feed completly to car?
j sizzle
« Reply #4 on: 11 May 2009, 21:26 »
Thanks for the replies. The crank sensor and the coil pack have been changed. It seems to be a temperature thing (after reading some other threads I now see that 96 isn't that high!) There is no spark to the engine when it occurs. To change the hall sensor will I need a whole new dizzy?
Offline danny_p
« Reply #5 on: 11 May 2009, 22:06 »
plug laptop into the obd port and ask it whts wrong  may give usefull clue
« Reply #6 on: 12 May 2009, 15:34 »
ok next time it does it check for 12v at the black wire to the coil with the ignition on :)
