Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 359664 times)
Offline Horney
Re: Horney's trackday MKII 8v - Project late 80's BTCC replica.
« Reply #830 on: 23 August 2010, 20:45 »
Me? Weld? :grin:
I might get marcus to take a look at it though and see what he thinks.
nick
Offline Paul86S2
« Reply #831 on: 24 August 2010, 21:32 »
I was hoping to take it to an Auto Solo in mid september but that's looking a bit unlikely unless it passes easily.
Nick
What class was you going to run in? I thought you had to retain the original interior to qualify to compete in Auto Solo. Or do they have a specials category.
Paul
Offline Horney
« Reply #832 on: 24 August 2010, 22:33 »
Spot on. Me and Mark will be running in Class F which is for specials or highly modified road cars. No chance of picking up any silverware but should still be a chuckle.
Nick
Offline Horney
« Reply #833 on: 29 August 2010, 09:17 »
Well yesterday was a result.Baffled sump and windage tray fitted:
Had to trim a bit more off the baffles to clear the pick up pipe but it's all on, filled with oil and pressures seem to be OK. I suspect there's still small bits of plastic floating around so I plan on dropping the sump off again in a months time and checking the pick up pipe again.
Today I need to fit my upgraded headlight loom and tidy up the car, clean it and double check everything works for the MOT on Tuesday morning.
Nick
Offline leeroy20vt
  • h reg mk2 gti
« Reply #834 on: 29 August 2010, 10:13 »
sump looks good horney were did u get the bits from if u dont mind me asking
good luck with mot on tues bud
Offline Horney
« Reply #835 on: 29 August 2010, 10:25 »
Mark (Veedubgti16v) made them for me from a template and his mate Si welded them in for me.
Nick
Offline Horney
« Reply #836 on: 29 August 2010, 12:05 »
Uprated headlight loom all fitted and working. Well impressed with it TBH. £35 delivered and it's been made to a very high standard.
Just gotta clear it out and give it a wash and tidy and it's all set for Tuesday morning.
Nick
Offline Horney
« Reply #837 on: 30 August 2010, 19:25 »
All set. How bad do we reckon the fail list will be?
Nick
Offline JC
  • Back in the North.
« Reply #838 on: 30 August 2010, 19:29 »
 :lipsrsealed:
 :grin:
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #839 on: 30 August 2010, 20:12 »
It still looks dead cool Nick  :smiley:
Keeping schtum. Mostly.
