Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 358935 times)
Offline Horney
Re: Horney's trackday MKII 8v - Project late 80's BTCC replica.
« Reply #820 on: 15 August 2010, 16:33 »
1/2 a point to Mr Frankland. Another 1/2 point to whoever guesses what the "crap" is :grin:
nick
« Reply #821 on: 15 August 2010, 17:03 »
Instant gasket, remains of the baffle plate or old gasket.
Offline Horney
« Reply #822 on: 15 August 2010, 17:09 »
1/2 a point to you sir! It is indeed what's left of the plastic baffle after my engine ate it. The pick up was so clogged you couldn't even suck through it!!!!!!!
I don't understand how it could have come off as I spent ages making sure it was fitted properly the other month when I pulled the sump off for the paint in the strainer issue.
Anyhoo Mark has taken my sump away to weld some proper steel baffles in it and I shall be picking up a windage tray and Derv Gasket this week. Will reassemble, fully engine flush, refill with oil and see if it's OK.
Nick
Offline T_J_G
« Reply #823 on: 15 August 2010, 18:18 »
Hope it's okay Nick.
Offline Jack3559
« Reply #824 on: 15 August 2010, 18:37 »
Anyone want to guess what this is then?
Nick
to me, it looks like a sump with a load of crap sitting in the bottom of it  :lipsrsealed:
+1
That's definitely a sump.  :laugh:
Offline Horney
« Reply #825 on: 18 August 2010, 10:22 »
Windage tray ordered. :cool:
Nick
Offline Horney
« Reply #826 on: 23 August 2010, 13:46 »
Windage tray has arrived, sump has been baffled (cheers Mark and Si) and uprated headlight loom ordered (Was an advisory on the last MOT).
Just discovered the MOT runs out on Wednesday so need to crack on this weekend flushing the engine and fitting all the bits and get it in for a test next week and see what horrors come up. I'm fully expecting some welding on the chassis leg :sad:
nick
Offline JC
  • Back in the North.
« Reply #827 on: 23 August 2010, 13:52 »
about time you sorted this out - oh and speed tape and some white paint  :wink:
Offline Horney
« Reply #828 on: 23 August 2010, 13:55 »
I did delay for a couple of weeks cause I was fed up with it but the last couple of weeks have been waiting on parts/fabrication.
I was hoping to take it to an Auto Solo in mid september but that's looking a bit unlikely unless it passes easily.
Nick
Offline archie837
« Reply #829 on: 23 August 2010, 20:40 »
If you need any welding done mate, Marcus will sort you out. If you can weld yourself, I got a beetle you can crack on with!
Project longterm Airbanger.
PD150 Anni daily
