Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 360405 times)
Offline Horney
Re: Horney's MKII 8v - Less valves, less weight. Fact!
« Reply #470 on: 21 December 2009, 11:30 »
I'm just struggling to see the benefit of fitting (presumably) four-point harnesses. Because they're better than the OEM 3 point inertia belts. I'm happy to admit that 5 or 6 point will be better again but 4 point correctly fitted are perfectly servicable in a car used for trackdays.
Why not use the seatbelts that are fitted OEM? Because with the bucket they are not very good at keeping you pinned in the seat in the twisties.
Unless you're going for a 5/6 point harness, of course. See above
Black seats are faster - you just can't see them being faster cos they are stealth, innit. Ahh good point, perhaps "Track camo" seats could be made for those extra few tenths :grin:
Nick
VeeDubGTI16v
« Reply #471 on: 21 December 2009, 14:58 »
sew your name onto the headrest for 20% more power  :afro:
Offline Horney
« Reply #472 on: 23 December 2009, 11:20 »
Well it's currently doing a pretty good impression of an iceberg.
Nick
Offline Horney
« Reply #473 on: 15 January 2010, 15:20 »
Well it's still not moved since Decembers No-Rice but I've got an old GTI drivers seat that I can now butcher to make a subframe for the bucket and Mrs Horney is buying me an Oil Pressure Gauge for my birthday.
I've also booked myself on a Trackday at Castle Combe on 25th June.
Nick
Offline Horney
« Reply #474 on: 16 January 2010, 16:34 »
Just ordered a DIN gauge pod for the oil pressure gauge. Takes 3 gauges so will also get myself an ammeter guage and one other but don't know what.
Nick
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #475 on: 16 January 2010, 16:46 »
oil temp ?
 i know the MK2 has one on the MFA but something more reliable you can keep an eye on ?
Offline Horney
« Reply #476 on: 16 January 2010, 16:48 »
Good idea as the MFA isn't the easiest thing to read!
Nick
Offline Jay
  • balding fat cvnt
« Reply #477 on: 16 January 2010, 17:43 »
EGT? Exhaust pressure? Fuel pressure?
I think you'll need another 3 pod DIN  :grin:
Offline Horney
« Reply #478 on: 17 January 2010, 01:17 »
Big Update!
When theis car was built back in the day it had the VSAM Pro engine management fitted to it which in a nut shell is an ECU that controls the timing and also controls and extra (Digifant style) injector which is mounted in the metering head. THis allows you to fine tune the K-Jet system for engines in a higher state of tune.
THis is all good stuff except VSAM Pro is very much an antique in the aftermarket ECU world and as it pretty much pre dates the internet information is scant to say the least. However I after much searching I found a chap in Oz who used to libve here and ran it on a KR powered Corrado. THis guy is a legend, he's managed to find a copy of the software for mapping it and is sorting me with a wiring diagram to make up the cable. I just need to pick up a cheap old lappy that has a serial port and Windows 95 or 98 and I'm away!
Nick
« Last Edit: 17 January 2010, 01:21 by Horney »
Offline Diamond Hell
  • Opinions я Us
« Reply #479 on: 17 January 2010, 19:30 »
Third one should be a mixture gauge, running off a lambda.
That way you can see when the K-Sh*t is running lean in preparation to detonate your engine.
