Author Topic: Horney's 'James Shead' 1988 BTCC Golf GTI replica build.  (Read 360490 times)
VeeDubGTI16v
Re: Horney's MKII 8v - Less valves, less weight. Fact!
« Reply #460 on: 20 December 2009, 13:53 »
nice!
bolt it to the floor pan and give your dad a cushion to drive it  :laugh:
Offline Horney
« Reply #461 on: 20 December 2009, 14:08 »
Ha ha yeah he'd love that!
Hopefully picking up knackered GTIseat over the crimbo period which I'll start hacking apart and measuring up for subframe purposes.
Nick
Offline Paul86S2
« Reply #462 on: 20 December 2009, 20:33 »
Makes sense.  Just make sure it's fitted up right and that the seatbelt works properly in it.
Aye aye cappen. Initially just going to be used on the road with the standard belt but will be getting a harness bar and captive nuts welded in before the next track session.
Nick
Are you getting the harness bar purpose made? Or a standard off the shelf one?
Paul
Offline Horney
« Reply #463 on: 20 December 2009, 22:13 »
I've not seen any off the shelf ones so I'm hoping to get someone to weld a bar between the rear turrets.
Nick
Offline Diamond Hell
  • Opinions я Us
« Reply #464 on: 21 December 2009, 00:33 »
Make sure it's got spreader plates welded into the turrets and make sure the bar is large enough diameter and an appropriate gauge.  If you drill through it to attach the harnesses (which you shouldn't need to) you should sleeve and weld any holes with tubing.
I really, really don't like this whole 'bodge a bar in for harnesses' thing instead of fitting a proper cage - it rather skips one of the huge benefits of having a cage - avoiding death in an accident.  I've said it before and I'll say it again - do it once, do it all (cage + harness + buckets) and do it right - it's why it's taking me so long to scratch the cash together to do my 'safety package' on the Syncro.
Obviously the harness you're getting will have 3" shoulder straps, won't it?
Offline Horney
« Reply #465 on: 21 December 2009, 08:37 »
Make sure it's got spreader plates welded into the turrets and make sure the bar is large enough diameter and an appropriate gauge. That's exactly what I'll be doing (well having done cuase I can't weld for toffee) If you drill through it to attach the harnesses (which you shouldn't need to) you should sleeve and weld any holes with tubing. They'll be looped round and not using eyelets in the bar.
I really, really don't like this whole 'bodge a bar in for harnesses' thing instead of fitting a proper cage - it rather skips one of the huge benefits of having a cage - avoiding death in an accident.  I've said it before and I'll say it again - do it once, do it all (cage + harness + buckets) and do it right - it's why it's taking me so long to scratch the cash together to do my 'safety package' on the Syncro. I agree with what you're saying BUT I am massively skint so it has to be a compromise between doing everything to the car I would like to do or actually using it on track. If I spend all my money on a cage then it won't be seeing any tarmac for the foreseeable future. If the dream situation of me getting my bonus for staying at work till the end and then walking straihg tinot a new job happens then I'vbe already told the wife she can have all the money left over after the Golf has had a cage welded in, ha ha
Obviously the harness you're getting will have 3" shoulder straps, won't it? Of course, I'm not a complete idiot!
Nick
VeeDubGTI16v
« Reply #466 on: 21 December 2009, 09:33 »
make sure you fit the seat the right way wont you
obviously you are going to use weld and not prit stick arent you
im really not a fan of yellow seats, blue ones are much safer, arent they?
Offline Horney
« Reply #467 on: 21 December 2009, 10:13 »
But everyone knows red is the fastest colour, should have got a red one, damn!
Nick
  • Opinions я Us
« Reply #468 on: 21 December 2009, 11:17 »
I'm just struggling to see the benefit of fitting (presumably) four-point harnesses.
Why not use the seatbelts that are fitted OEM?
Unless you're going for a 5/6 point harness, of course.
Black seats are faster - you just can't see them being faster cos they are stealth, innit.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #469 on: 21 December 2009, 11:24 »
Oh dear.. Reading this thread is making me giggle.. albeit I would be gigglinf properly if it wasn't so FREAKING COLD.
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
