Author Topic: 16" wheels any recommendations for purple gti?? pics pge 2!  (Read 4405 times)
Offline robz
hi all,
what wheels would you recommend for my purple gti??
its got 17" rs4's on now, but they are too big and i get alot of arch rub!!!
would anyone want these for a swap for some 16's?
any thoughts considered!!
cheers!
« Last Edit: 09 May 2009, 23:06 by robz »
Offline 6sr
Re: 16" wheels any recommendations for purple gti??
« Reply #1 on: 08 May 2009, 11:47 »
These would be ideal.
http://www.golfgtiforum.co.uk/index.php?topic=114513.0
They're very similar to TT comps, but are 16's and lighter too.
Offline Dec
« Reply #2 on: 08 May 2009, 11:59 »
16" Merc wheels with stupid low profile tyres are a winner :P
Offline robz
« Reply #3 on: 08 May 2009, 12:03 »
not keen on the tt comps...
but thanks for replying!!
the merc wheels are bloody gorg!!!
but its either a straight swap of whatever i could sell mine for and get new with!!
money is tight at the mo... and i dont think this rubbing is doing it any good, lol
cant even do a national road properly, go down a dip and back up it does an all wheel rub!! lol
cheers!
« Reply #4 on: 08 May 2009, 12:06 »
Well worth checking 2 things on your 17"s, if it is not lowered they should not rub that much.
1) What offset are they, stamped on the wheel will be an et number this needs to be at least 35.
2) Tyres, 205/40/17 are the correct size
I ran 17"s with a 70mm drop and they only caught the rear arch now and then.
Offline Dec
« Reply #5 on: 08 May 2009, 12:22 »
Running my wheels Ive had to have all of the arches cut down a lot so its not really cost effective :/
PCD adaptors seem to be pretty pricey to fit merc wheels too :(
Plenty of nice wheels about though! Also, check what Wayne has suggested as if it is standard height, it should not rub that much. :smiley:
Offline robz
« Reply #6 on: 08 May 2009, 13:02 »
its been lowered quite far!!
but its the back it rubs most -
will check what et they are!!
even catches when i get 3/4 lock on??
pain in the arse really, lol
thatnks for the help though??
also, the ride is a bit crap, im guessng that ride quality will improve on 16's?
cheers.
Offline Dec
« Reply #7 on: 08 May 2009, 13:05 »
The ride depends on the suspension/tyres aswell as the wheel size but I would say it probably will improve :)
get some pics up mate :)
Offline Len
« Reply #8 on: 08 May 2009, 13:10 »
Any design you like but in GOLD!  :wink: :laugh:
www.sas.org.uk
www.the-ace.org.uk
« Reply #9 on: 08 May 2009, 13:53 »
cheers.
Sounds like your offset is wrong, this was mine, 7x17 (et35) with 205/40/17's, I had to trim the rear arch lips back but was fine but would still catch now and again if you had weight in the boot.
« Last Edit: 08 May 2009, 14:00 by Wayne »
