Author Topic: small wiring question.  (Read 2055 times)
Offline batman04
« on: 07 May 2009, 09:44 »
hi everyone, just fitting the stereo in my mk1 golf gti, just a quick question on the wiring up, i have a battery cut of switch inside the car that runs in betwwen the battery and fuse box to cut everything off when parked, also good anti-thief tool. i have run a new beefy wire from the battery to inside the car to the cut of switch then the fuse box wire connects to the other side, am i ok connecting my amp wire to that power coming into the car or does in need direct connection? it's a 2000w amp and a 3000w dual pioneer Sub.
Offline DanoGTI
Re: small wiring question.
« Reply #1 on: 12 May 2009, 06:01 »
Depends on if you want to listen to your tunes whilst everything's switched off :) If so, then direct connect....
Dan :)
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
