Author Topic: Auto Locking Doors  (Read 2612 times)
Offline edition_30
Auto Locking Doors
« on: 05 May 2009, 17:33 »
I'm sure that my doors used to lock automatically after I removed the key from the ignition and left it unlocked for a minute or so.. lately it has not been doing this.. any ideas on how to re activate.. I gave tried looking on the convenience menu but cant see anything
Offline ifti
Re: Auto Locking Doors
« Reply #1 on: 05 May 2009, 18:21 »
I thought they only locked automatically if you unlock the car, but then dont open a door for a minute or so, it then auto re-locks....
Never thought it locked when you remove the key from the ignition, as it wouldnt know if anyone was still inside! lol
Unless..............you've been leaving your car unlocked by accident!!!
Offline AlanD
  • MK5 2.0T 16v
« Reply #2 on: 05 May 2009, 20:18 »
The car will only auto lock itself if you unlock the car but don't open any doors. It won't auto lock if you have driven if or opended a door then leave it, it will remain unlocked till you lock it.
There is an anti hijack function which I have had turned on via VAGCOM. This auto locks the door when I go over 10mph and will auto unlock the doors when I take the key out the ignition.
Hope this helps.
Offline TagnuT
  • Edition 30
« Reply #3 on: 05 May 2009, 20:56 »
Hope this helps.
You can do it using the Highline MFD also.
Bye Bye Edition 30
Offline Holepunch
« Reply #4 on: 05 May 2009, 21:07 »
Hope this helps.
I couldn't find this option on my 06 GTi could it be it requires a software update before it appears?
Offline ifti
« Reply #5 on: 05 May 2009, 21:34 »
Hope this helps.
Yup, I also enabled this via highline....
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 05 May 2009, 21:40 »
I forgot to mention it may be doable via the highline lol
I dont have highline so wouldnt know :(
Offline smartypants
« Reply #7 on: 05 May 2009, 21:40 »
I can confirm that you can set this through the highline - have set it myself.
Offline ifti
« Reply #8 on: 06 May 2009, 10:41 »
Ive already confirmed it.
Thanks anyways.
lol
Offline smartypants
« Reply #9 on: 06 May 2009, 11:10 »
My confirmation was better than yours
:D
