Author Topic: 8v Replacement Lower-Pulley Bolts?  (Read 3183 times)
Offline Diamond Hell
  • Opinions я Us
Re: 8v Replacement Lower-Pulley Bolts?
« Reply #10 on: 14 August 2011, 07:52 »
No, not in my experience.
Offline danny_p
« Reply #11 on: 14 August 2011, 10:30 »
GOOD QUALITY HEX KEYS play a massive part in haveing sucsess with them.
if there really crappy it's maual inpact drive as DH says,   most of the time i just scrap out the hole and make sure the hex key is located fully home with a good wack from a hammer the use the air inpacter ( cos it's easy )
all the VW's have gone bar 1.
Offline motah33
« Reply #12 on: 14 August 2011, 13:03 »
Thanks guys. That last time I had a quick look at it when I tried to turn the pulley bolts the pulley moved, which is why I was asking if you a re supposed to hold the big centre bolt with a rachet or something, to hold the pulley still, while trying to turn the 4 pulley bolts?
Thanks
  • Opinions я Us
« Reply #13 on: 15 August 2011, 16:01 »
Impact driver gets around the pulley wanting to turn, as it's a shock, rather than 'turning pressure' as it were.
19mm bi-hex socket if you need to hold the crank.
Offline Ben Lessani
« Reply #14 on: 23 August 2011, 12:25 »
I use the pikey impact wrench ...
A 6mm hex socket, 3/8th ratchet and 3lb hammer :)
