Author Topic: Electric Window Problems  (Read 2471 times)
Christo77
Re: Electric Window Problems
« Reply #10 on: 03 May 2009, 00:25 »
Hey thanks for that.. i'll pull the regulator out, seems likely what's happened
Christo
Offline karl29
« Reply #11 on: 03 May 2009, 07:42 »
hope you get it sorted if it is a cable you need to pull it back with a pair of grips and it should be ok
Christo77
« Reply #12 on: 05 May 2009, 19:17 »
Thanks..I'm still yet to tackle it actually..  does the whole regulator arrangement come out easilly?
Offline hammonds
« Reply #13 on: 05 May 2009, 22:17 »
easily enough, just undo a few bolts. might have to force the window(gently) down to gain access to the bolts clamping the window in place.  The hardest bit is trying to pull the thing out and put it back in, just takes a little time and a bit of trial and error. its a bit like a logic puzzle.
Its pretty self explanatory once you get the door card off and have a look at it.
Christo77
« Reply #14 on: 06 May 2009, 16:44 »
Had a feeling it was gonna be fiddly..i think i'm putting the job off hehe..
Thanks for the info  :wink:
