Author Topic: Electric Window Problems  (Read 2470 times)
Offline percymon
« on: 29 April 2009, 16:08 »
Got the following issue..
The switches in the drivers door have eratic behaviour.   One day they work fine (operating both nearside and offside front windows), the next the offside window won't do anything and the nearside window will go down but not up - i can close this with the switch on the passenger door (not ideal when driving!).  Occassionally the drivers window will go down but not up, at which point i have to use the key in the doorlock to close it.
I've stripped the switch int he drivers door panel, cleaned contacts etc but no change.
I suspect its the window regulator, but why would i have issues with both the drivers and passenger window at the same time ??
Anyone had any success just cleaning and relubing the regulator mechanism ?
Offline mbGti
Re: Electric Window Problems
« Reply #1 on: 29 April 2009, 16:37 »
If the window will go up and down, but is tempremental about which button you use it is unlikely to be the mechanism.
When you say its erratic from a particular switch does it go up then come down again, or will it simply not move at all.
Offline steve113
« Reply #2 on: 29 April 2009, 16:52 »
check the wiring when door fully open inside the black rubber sleave could be broken wire  or wires or could be a  faulty window switch
Offline oliver07
  • golf gti T 200BHP
« Reply #3 on: 29 April 2009, 16:55 »
also check the door handle if this has been removed ie to take the door panel off the  wires can get damaged this was the case with mine :wink:
Offline 6549steve
« Reply #4 on: 30 April 2009, 01:09 »
i had the exact same problem.  when the door is fully open, pull the rubber sleeve off from the car body (dont unscrew the plastic connector from the car body, just pull the hose off the back of it) and you will find some severed/bared wires, just re-join a severed one/ tape round bared ones and it should be problem solved.
dont do what i did and buy a new switch off ebay without even looking for the problem
Offline percymon
« Reply #5 on: 30 April 2009, 19:11 »
Bang on the money Steve !  Pulled back the trunking to find a thinnish brown wire with some wear on the insulation and a thick red/yellow wire broken. Just used an in line torpedo type connector to jointhe two ends and increase the length by an inch which can only help as the cable was very tight withbdoor fully open.
Thanks very much ;)
Offline hammonds
« Reply #6 on: 01 May 2009, 17:27 »
I'm having a similar problem, except neither my driver or drivers side passenger windows work at all.  I can here a click within the doors when i push the switches (on the doors and the dash) suggesting that there is life somewhere.  I've checked the wires, all of which appear to be in good condition.  Just wondering if its the regulator and that its coincidence that the two on the same side have died.
Failing that could it be a fuse issue?  Or is there one fuse covering all the electric windows?
cheers
Offline 6549steve
« Reply #7 on: 02 May 2009, 12:12 »
i would imagine there would be 1 fuse to work both windows, but i didn't see one in the fuse box when i was checking.  but maybe there's an in-line one somewhere i'm not sure
Christo77
« Reply #8 on: 02 May 2009, 22:23 »
My driver window is now stuck closed, was a bit temperamental previously, you can hear it clicking and the revs drop when hitting the button, so i guess i'm getting power to the window motor, i've had the door card off and fiddled tapped clouted banged sworn and growled a lot to no avail! :grin:
Offline karl29
« Reply #9 on: 02 May 2009, 22:33 »
i had similar problem i could hear a click when pressing the button i took the whole window regulator out and 1 of the cables that move the window had forced its stay out and jammed it it may be worth looking at
