Author Topic: What does it do?  (Read 1392 times)
Offline lukesGTI
What does it do?
« on: 27 April 2009, 19:11 »
I have installed a k&n induction kit on my 8valve but where do i put that round sensor that goes in the air filter box? i have disconnected it for the moment and miraculously my missfire problem is calmed down, could that sensor if naf cause a missfire?
Offline grimmer
  • www.check-light-on.co.uk
Re: What does it do?
« Reply #1 on: 27 April 2009, 19:47 »
that is the air intake temp sensor, dont really do alot to be fair, its normally the sensor that the dodgy ebay 10+bhp resistor thing goes across. best to just drill a small hole in the neck of the filter and push it in there.
MK3 GOLF GTI 8V  now converted to 16v!!
Offline Mikester
  • Civic Type R
« Reply #2 on: 27 April 2009, 21:22 »
NOOOOOOOOOOOOOOOOOOOOOOOOO!!!!
Dont do that.. Bad bad bad.
If the cone is the correct one for your car, it will have a hole already made in it for the sensor to push into, on the back of it.
I have a KN on an 8v, and it has the hole to put the sensor in.
kells
« Reply #3 on: 27 April 2009, 21:41 »
must be different to early cars then as i have no sensors hanging and no holes in the K&N
Offline Mikester
  • Civic Type R
« Reply #4 on: 27 April 2009, 21:45 »
different MAF, so maybe the sensors is different.
All i know is, i have the sensor, and i have the hole to fit it. And i didnt find the hole at first, so do give it a propper going over before you destroy it with a drill, as they are expensive those KN's
