Golf mk3
hardmonkeys
major clunk after disc and pad change
Topic: major clunk after disc and pad change (Read 1790 times)
maverick1984
25 April 2009, 11:08 »
Changed the discs and pads and now when i am going very slow-lets say 5 MPH- and i take my foot off the accelerator there is a really loud clunk coming from the passenger side front. it does not do this when i am braking or going at higher sppeds.
Help me please before i go insane over this car!
Guy
Forum addict
Re: major clunk after disc and pad change
25 April 2009, 11:28 »
you fix the caliper back on?
** need web hosting? contact me **
maverick1984
25 April 2009, 11:33 »
Yea put that back on properly
maverick1984
25 April 2009, 13:46 »
Right i went back out and put the old disc and pads back on and it is still doing it. I owned a Hyundai coupe once and it did this and in the end it was the lower arm ball joints.
Do you think it could be Bushes?
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
25 April 2009, 15:42 »
Did you fit the anti rattle clips? they can cause the pads to move about and drop..? usualy happens when reversing or rattles over bumps though.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
maverick1984
25 April 2009, 16:54 »
Yes put them back in
Rmachines
Reply #6 on:
26 April 2009, 12:42 »
Its an odd one, All i can think of is mabey the calipers are loose or the disks now have a bit of free play since the retaining screw was removed, but i doubt that as the wheel bolts should clamp em' tight!
maverick1984
Reply #7 on:
26 April 2009, 12:48 »
This clunk only happens when going at very low speeds in first gear. if i have the clutch pressed in then it does not happen. its only when i am going about 5mph and i take my foot fully off the accelerator. Do you think it could me something to do with the drive shaft?
all discs and pads are secure.I went and bought 2 more retaing screws from VW.
Rmachines
Reply #8 on:
26 April 2009, 12:59 »
Check these out, Engine mounts > Drivbeshafts > Gearbox All of those could cause that.
Cable
Reply #9 on:
26 April 2009, 22:01 »
its probs the bushes for the lower arm
Golf mk3
hardmonkeys
